nct tomorrow
scoobysub
booked in for the nct tomorrow. it failed the last time on emissions and some small things which are now fixed . i was going to get diptane and add it .will it help or a waste of time
Dipetane's a waste of time man, made absolutely no difference to mine anyway,
but best of look with the test :thumbsup:
diptane should make a difference in yours i think
make sure to have the car nice and hot when you go in
all the best with it Joe :thumbsup:
its a bit late to put it in joe,
really you should be using it a week or two but it does work for sure
as colm said, make sure the cat is nice and hot
cheers lads :thumbs up: might give it a go dont wan the hassle of a re test .
another quick question . do i need to get an rf100 form filled in if i want to tax it from may on . have it since september but its not being on the road . will they try and charge me back tax .
We use dipitane in work as we do DOE's aswel, drop of dipitane and a scorch up the road and its okay. It wont be a massive drop but it helps in diesels, dunno about petrol cars :icon_grin:
joe ive used dipetane on my cars before its great stuff but both mine were standard so maybe that helped,it is good stuff each division on the bottle will treat 10 litres i usually use maybe a quarter bottle and give it a good drive making sure the cat is nice and warm as said above :thumbsup:
GORDON GT SERIES II said:
jaysus joe it should be fine it lookes to be a well minded car before and more so now best of luck anyhow :thumbsup:
well minded has got nothing to do with passing the nct depending on who you get and what mood he's in :wall:
dipetane only works if you use the right amount as stated on the bottle, i find alot of people just throw the full bottle in thinking it will make a huge difference but it doesnt. It wont get your emissions down hugely maybe only 1-2% but them 1-2% could be the difference between a pass and fail.
Anyway good luck with the nct hope you pass :thumbsup:
Dipetane will help abit, but maybe give the spark plugs a clean or change them if needs be. Hope it passes for you too.
Legend Joe :dance:
To answer your earlier question, rf100 form is needed and a trip to the cop shop to get it signed and stamped :thumbsup:
