Rear 2 pot calliper adapter Brackets fits both brembo and Subaru 2 pots
nivek4209
Hi folks
I have a few sets of these for sale if anyone's interested
These are required to fit 2 pot rear calipers in place of the single pot ones
40 euro delivered within the republic gimme a call on
0863640945 or email me on [email protected]
Any idea if these Will allow the front calipers and discs from a 99 B4 to be transferred to the rear?
I highly doubt it they are designed for the Subaru 2 pot rears and brembo 2 pot rears from newage Sti s to be fitted to the rear of models that only had single pot rears to start with
Absolutely no way, sure the disks are not going to fit over the handbrake shoes. Offset on the calipers will be different too.
will these work ugrading 1 pots to 2pot standard subaru are brembos and standard 2pots diffrent spacings?
The Type R has 290 rear discs and the Sti Brembos have 315 , can 315 discs fit the version 5/6 type R with the Subaru 2 pots instead of the 290 discs or will only the Brembo 2 pots do?
Only the brembo calipers will work properly with the larger discs
Also ya don't need my adapters if your car is originally fitted with rear 2 pots the brembo caliper and discs will bolt straight on ya will need different bolts though
I just want to be clear, will these allow me to fit Impreza 2 pots on the back of my 99 BE5 legacy? Do I have to change the discs too?
Just in case this only applies to Imprezas.
Cheers,
Mark.
Cheers,
Mark.
No they are different you need the kartboy brackets
