Hi lads,
I've a weird one. The rear driver's side window won't go up??
Goes down no probs.
Even from the driver's controls it does the same....down, no up.
All the other windows are fine.
I had to take the doorcard off to get it back up. I got a motorcycle battery and was able to jump the motor. Widow does up and down fine depending on the + / - I use so I know the motor is good and the glass is running fine along the runners.
Last thing I tried was to swap the left door switch with the right but no joy.
It's hardly a fuse is it? Kinda stumped as wnat to try next??
Any ideas??
Cheers
Goes down no probs.
Any ideas??
Cheers
