mac mac said:check this out , 18x9 on 225/40 rota g force![]()
any info on what a lad would have to do to make this setup work , wings rolled and pulled , ride height ????????![]()
have cusco coilovers , with adjustable top mounts ..
any help appriciated
just gathering info
forester sti said:Sure just take 5mm off the offset and put 245/35's on the 9" rims!
2deg neg camber is slightly on the agressive side! tires would be pricey enough!
forester sti said:I use 1.5deg neg for the road and it does wear slightly but noticably on the inside!
I use 3deg neg on track and it lashes tires out of it, but she turns in beautifully!
Can you get those wheels with any offset??
It would be well worth trying a few different spacers to figure out the best off set!
I'd get a geometry setup first so your camber is set and then try some spacers!
forester sti said:I'm sure they can!
And a stretched tire feels better than an oversized one!
No tire flex at all!
mac mac said:cheers for all the info lads ,
lookin on wheeldude and 18x9 gforce $900 + $600 delivery = $1500 for just the rims which is about 1100 yo yo s
@ dan , plan would be to get it all done in one go , wheels +geometry setup
