So since the last update I have been tipping away and small but important parts of the project
First up was the fit new front wheel bearings. I brought the struts over to Dec and he pressed out the old ones and pressed in I nice new set of bearings. Big thanks to Dec for this, he is always on hand when needed with this car. The bearings are something I never mind doing every year as they are a cheap part to replace.
Now that I had these sorted it meant I could start to put all the front suspension back together. I also fitted new rear pads and gave all the calipers a good clean and free all pins. These were all fully rebuilt last year so still spot on. The front RC5+ pads have loads left and will easily see me out for 2020.
I completely flushed all fluid and replaced with AP Racing 5.1 again this isn?t expensive and it?s all I have ever used to great effect.
So that?s really loads of small bits done and out of the way. Another small job I needed to do was make a bracket for my oil dip stick. While fitting this back on the old bolt snapped in the head. Completely my own fault as I should have replaced it. Only awnser for this was to make a big Gay aluminium bracket like so...
I also replaced the bolts I had on the charger bracket for new 10.9 m8, the other ones were just old gearbox bolts I had to temporarily hold it in place. Very close to getting it fired up now, all oils are done and all that?s really left is to fit the new charger belt dnd make up the down pipe for the charger. I have contacted Omex for a base map to start on. It would probably start on it?s own map but it?s no harm having a better one if possible.
