the beast is alive said:but could i put newer loom in so i would be running unlead then able to get remap later
the beast is alive said:worth try no short cuts then simtec it is then just 1000 euro is hard gather up when insur and petrol are on rise
scubbay said:Its not super complicated or impossible. Ive seen classics running version 7 engine loom and ecu. Is it worth it though? Id never call it stupid Ken. If the parts are available foc then knock yourself out. But the best/cheapist solution would be a power fc.
I run a version 3 with version 5 heads and a version 7 manifold with top feed injectors. Ask if it can be done on a Subaru forum and you will get shot down. No icv of any kind either! Stupid-no, trying to get the best from my car-yes. etc etc as you say
Its good to step outside the boundries, especially when you whip cars with 100 bhp more than yourself.
KENC said:scubbay said:Its not super complicated or impossible. Ive seen classics running version 7 engine loom and ecu. Is it worth it though? Id never call it stupid Ken. If the parts are available foc then knock yourself out. But the best/cheapist solution would be a power fc.
All the above work for an end result of geting a mappable v5 v6 ecu that will cost probably near 1k to ecutek map anyway instead of just buying an Apexi or simtec from the start etc etc is just Plain Stupid dont matter what way you put it.
