[quote author=goosie208 link=topic=35596.msg408717#msg408717 date=1347876227]
agreed , no point taking it upto the redline, mines never been over 6.5, and rarely above 6
fuelling is very important, they are a higher compression ratio to Imprezas, 9 as oppose to 8.5 so will be more inclined to Det more than Imprezas
take car of it and it will take car of you, service mine every 3k miles with good oil, use good plugs, only use E5,
if your going to rag it, maybe a stand alone oil cooler,
and also a tip, ignore anything anyone tells you about installing silcone vac lines, or re doing the solenoid box with them, leave it as subaru intended, clean them out periodically but leave them OE, that is unless one breaks, then you dont really have much choice,
uuuum what else....... standard breaks are RUBBISH, maybe invest in some 4 pots, and good pads, steel lines
the Bilstein dampers tend to start to knock with age, but i suppose thats common on cars of this age, even the newest ones are almost 10 years old
i think the main concern if you get one is to get it mapped to E5 or 95 so as to make sure the fueling is ok, i say that though, i havnt
if u got one standard enough i would proably leave it standard apart for a few changes, but as it goes for mapping, i gues most legacys are brought in and then people dont bother remapping for 95ron fuel, so what happens if ur out and u need to fill up and the station doesnt have octane booster, do u just fill up and pray
it doesnt f@%k the engine up? or heighten the chances of detonation? so i gues the power rating on any legacy the is remapped to 95 is brought down from the 280 on the rsk to 250bhp? and to bring that back up you put on a new air filter and exaust but you can only remap the 2001 model on??????
so so far here is a list iv just guessed so far
rsk editions are slightly more powerful(but differences between it and standard can vary ie..the aero kit,etc)
even well maintained ones can fail
comfier than an impreza(able to keep up but not in the corners?)
gen 4's can be somewhat more reliable. cant remember where i heard that(or if there is any truth in that?)
all twin turbo models have a momo steering wheel? (not sure about the auto's but i stand to be corrected on this line)
i still havent figured out which model has the half leather interior the rsk alone on both
seen a vid on one going uphill on snow and ice and other vids, so fairly impressed with the awd,
actually here one vid i seen
http://www.youtube.com/watch?v=ooQRxlChvMw go to 07:50 for the legacy.
there cheap enough but the gen 4's seem to be pricey enough
holds the road something serious(iv been told)
bad on fuel iv you gun it at all
what am i missing?
