Thanks got under there while car was on ground. No movement in the arb itself or at the bushing. Cheap part though so worth trying. Drop links look ok to me.The noise is very similar to a dry anti roll bar bush , quick way to check is drop the 2 anti roll bush clamps and use a good grease on the inside of the bush , put it all back together and see if that cures it .
Check the links for play also , if replacing use Genuine Subaru links as the ball joints in those last a lot longer than cheap aftermarket links
