555-Scooby
Reading that article would you consider a turbo car a STANDARD PETROL CAR.....??????
Official statements on E5 and E10 from Australia and New Zealand suggest that ethanol blends are unsuitable for use in many cars with turbos, as well as in secondhand cars imported from Japan.
Could you please comment on this as it is of great concern to those of us who drive Subarus and similar cars?
[size=10pt]In the light of the introduction of Maxol E5 ethanol blended petrol in Ireland, could you please comment on the following statement from Subaru New Zealand?[/size]
Tuesday, September 4th, 2007
[size=10pt]Ethanol compatability[/size]
Most Subarus purchased new in New Zealand since 1990 are capable of running on the ethanol blended fuel now being introduced to the local market.
However any Japanese domestic specification models which have been imported here second hand (i.e., second hand Japanese imports) - should not be run on the ethanol blended fuel.
These cars are only suitable for 3 percent blended fuels. The fuel being sold in New Zealand has a 10 percent ethanol blend.
The 10 percent ethanol blended fuel could cause damage to the fuel line, fuel injector sealing, fuel pump or fuel regulator of these second hand Japanese imports. The fumes from the blended fuel after combustion can also have a harmful effect on the catalytic converter, the exhaust gas regulator and the muffler.
Those Subarus which can use the 10 percent ethanol blended fuel have a 17 digit VIN number beginning with either JF1 or JF2. The VIN number can be found at the bottom of the central door pillar on the passengers side of the car or in the engine bay.
The second hand Japanese imports which should not use the ethanol blended fuel have VIN numbers starting with 7A8
A small number of models sold new in New Zealand cannot use the 10 percent blended fuel. They are.-
Legacy RS, Legacy GT, Legacy GTB, Legacy RSK and Legacy Blitzen from 1990 onwards; the Impreza STI from 1997 onwards and the Forester STI. They do not have JF1 or JF2 VIN numbers.
Owners who are not sure if they can use the ethanol-blended fuel in their car should consult their nearest Subaru Authorized Dealer.
IN SUMMARY
DO NOT USE Ethanol Blended Fuel E5 or E10 if your car is:
A Subaru with VIN Number that starts with 7A8
or
Second hand Japanese imported Subaru
or
A New Zealand New Subaru that is any of these models:
- Legacy RS, Legacy GT, Legacy GTB, Legacy RSK and Legacy Blitzen
- Impreza STI
- Forester STI
Your car CAN USE Ethanol Blended Fuel E5 or E10:
Only New Zealand new Subarus models 1990 onwards with a VIN number beginning with JF1 or JF2 may use E5 or E10 blended fuels
Note: The VIN number is a 17-digit number that can be found at the bottom of the central door pillar on the passengers side of the car or in the engine bay.
[size=10pt]These issues are presently under discussion on the website of the Irish Subaru Drivers Club and Im sure that a clarification from yourselves would be greatly appreciated by Subaru drivers all over Ireland.[/size]
[size=10pt]Thank you for your email, but it seems to have been in reply to an enquiry from another Subaru driver in Co. Donegal and does not answer my question, which was:[/size]
[size=10pt]Let me elaborate:
The Federal Chamber of Automotive Industries in Australia has stated that the vast majority of imported new cars sold in Australia are also compatible with E10 or E5. The essential thing to note however is that if your car is a performance car, specially turbo or supercharged, then ethanol fuel may not be for you and specifically listed the turbo Subaru Liberty/Legacy B4 (2002 to 2003), Liberty/Legacy GT (2004 - 2006) and Impreza WRX STI (1999 to 2005) as being unsuitable for use with either E5 or E10.
Whilst Subaru New Zealand has recently issued the following statement:[/size]
IN SUMMARY
or
or
- Impreza STI
- Forester STI
[size=10pt]Perhaps it depends on your definition of what constitute standard petrol powered vehicles? But as you can imagine, this is causing great confusion for many drivers who have had to endure inadequate 95ron for the past decade and are keen to use your new 99.2ron E5 petrol.[/size]
Stephen,
Thank you for your email. While accepting that Australia & New Zealand have made statements as set out by you below, regrettably, we are not in a position to comment on the performance of individual cars using E5. If your vehicle is not a Standard Petrol Engined Vehicle I suggest that you seek clarification from your motor Dealer who hopefully, through Subaru, can obtain clarification for you.
Sorry I cant be more helpful on this occasion.
[size=10pt]Technical reasons for inability to use E10 [/size]
The following are reasons why certain vehicle models cannot or should not use E10 because of material incompatibility and driveability issues respectively. There are also comments on possible exhaust and evaporative emissions issues. This list was compiled from information submitted by manufacturers.
Cannot use because of material incompatibility issues
Early deterioration of components in fuel injection system:
Fuel tanks
Fuel lines/hoses
Injector seals
Delivery pipes
Fuel pump and regulator
Vehicles with carburettor fuel systems may experience hot fuel handling concerns and may experience a lower level of durability in some fuel system components.
Some manufacturers advise not to use E10 with any model equipped with a carburettor because of material incompatibility.
Should not use because of driveability issues
Vapour pressure of fuel with ethanol will be greater (if not chemically adjusted) and probability of vapour lock or hot restartability problems will be increased.
Oxygen content of ethanol is 34.7%. This can cause the engine to run lean although the Engine Control Unit (ECU) can generally compensate via feedback from the O2 sensor under light throttle conditions. However, hesitation or flat-spots during acceleration can occur due to this lean-out effect.
Difficulty in starting and engine hesitation after cold start
Exhaust and evaporative emission levels
Lean-out resulting from the oxygenating effect of ethanol in the fuel may affect exhaust emissions. Fuel containing ethanol can increase permeation emissions from fuel systemcomponents.
Vapour pressure of fuel with ethanol will be greater (if not chemically adjusted at the refining stage) and can lead to increased evaporative emissions.
Subaru Liberty B4 (all year models) and Impreza WRX STI (1999 and 2000) do not operate satisfactorily on E10.
All other since MY1990 petrol engine Subaru vehicles will operate satisfactorily on E10.
